Nissan datascan is showing 204.8 F. It is 100 degrees outside. Is this within normal temp range? Also, my ignition timing is set at 15 but when i drove the car the timing changed to 21 and took a while to drop down. Is this normal? Lastly, my IACV makes a click sound (sounds like turning on and off) every 10 sec or so which makes my RPM go up and then settle down. Is my IACV bad or something else? I just did a plenum pull to change out some injectors. Sorry if these are dumb questions... dont really know much about cars other than tutorials posted here.
